Bluetooth proximity tags (neat)
http://sticknfind.com/product/
If there was a Tasker plugin for android, you could use it to send commands to the Vera. Or, if you could get a Low-energy bluetooth dongle working with Vera, a plugin for Vera could be coded directly.
These look way better than the Active RFID stuff that I use.
Interesting, but… even more interesting (I think) is another of their products -: http://meterplug.com/
Chris
[quote=“Chris, post:2, topic:174059”]Interesting, but… even more interesting (I think) is another of their products -: http://meterplug.com/
Chris[/quote]
Check out the other post I just did about the power strips and sensors. Ubiquity has clamp on current sensors that can be queried over the network. They are like $14 each, but you need the $79 gateway for this sensor. You could put it in your main panel.
Re-opening this. Any plugin for bluetooth based devices or simply use Tasker / Trigger?
