I’m trying to retrieve a devices key codes out of my saved Boxnet file for my Blaster. All I see is <UEISetupCode=“0775”> . This is for an old Dish Satellite Receiver.
Anyone know how I might get the individual codes out of this ?
I’m wanting to send a pronto code from a scene to turn off my old receiver.
Either as an attachment, or as a link to the file on some service (like Box or whatever). I’d need to see the inside of the file to see what the commands look like.
UEI codes are “references” into the internal Chip that handles the built-in IR stuff, so we’d need to see what was chosen for your specific Satellite system.
One more question if I may trouble you again. In the Pronto Code field, I would enter .
This would issue an “ON” command and works good. Is there a way to insert a label somewhere in the Pronto Code field so I know what command is being sent? Maybe like <US07752{Dish ON}> ?
It appears that doing this causes no problems and everything works but I’m no expert.
It’s not intended for that. No idea what the SQBlaster will do now, or with some future patch, since it’s not expecting to have the extra characters present.
Ok , I will leave things alone and how they should be. I’m not using the “< >” in the actual Pronto command.
I just didn’t want to forget what command I was sending later down the road. Getting older (retired) and things don’t come as easy as they use to !
Thanks…
