Just upgraded to vera2.
Turned on Blackberry access in dashboard marketplace.
Went to MO, entered my user name and pw, would not connect.
What step am I missing?
Blackberry access? You mean the standard smartphone plugin? What you’ve done should work! Which BB do you have? It works on my 9700
purl
Do you have a recent 5.X OS?
Still should work .
What messages are you getting if any.
Are you logging in locally same IP as Vera or through the IP of the cell phone company.
Do you have the " Require local http authentication" checked?
Does the Mios site accept the user and PW…
Are you getting a cookie or cert error?
Try the standard WAP plug-in maybe.
