Hello, Does anyone know about a Bitwise Controls Plugin?
I Need to integrate vera with bitwise controls either BC4 or BC1, this controller has IR, RS232, i/o and tcp/ip control capabilities.
If you a search on the forum for bitwise does not yield any results. It is most likely that a plugin does not exist and would require you to create one yourself.
- Garrett
