I have a vera lite UI5 and a raspberry with OpenHab
I can not receive data from true of openhab
where am I wrong?
I followed many guides but I can not fix the link vera → openhab
I insered a file in /etc/openhab/configurations/transform
Thank
zeno
where am I wrong?
Thank
zeno
Your config looks openhab.cfg looks correct:
mios:house.host=192.168.0.2
mios:house.port=3480
mios:house.timeout=30000
The last two settings are default, so they’re not strictly required (although they won’t hurt either).
Your items declarations look correct, but potentially using an older version of the Item Generator. That should be fine.
For reference, here are my old definitions, just before I stopped using MiOS Weather plugin:
Number WeatherHumidityId "ID [%d]" {mios="unit:house,device:321/id"}
String WeatherHumidityDeviceStatus "Device Status [MAP(miosDeviceStatusUI.map):%s]" {mios="unit:house,device:321/status"}
Number WeatherHumidityCurrentLevel "Outside Humidity [%d] %" (GWeather,GMonitorHumidity) {mios="unit:house,device:321/service/HumiditySensor1/CurrentLevel"}
So, based upon the instructions here:
MiOS Binding · openhab/openhab1-addons Wiki · GitHub
There are a few items that could be missing:
a) Installation of the MiOS Binding itself
If the binding is missing completely, then there will be radio silence in the openHAB log files, otherwise you’ll see evidence of it starting.
If you’re using Linux, and the apt-get install type, then that’s:
sudo apt-get update
sudo apt-get install openhab-addon-binding-mios
b) Installation of the MiOS Binding transformations:
c) What’s in the logs:
The binding will emit diagnostic information if components are missing, and/or having issues with connectivity.
with the commands
sudo apt-get update
I managed to read the humidity sensor
Urrrrraaaaaaaaaaaaaaaa
Thank @guessed
Zeno
