Beta - VeraMobile for Android v.7.50.760 / MiOS app v.1.0.759
We’re releasing a new Beta update for VeraMobile for Android v.7.50.760 / MiOS app v.1.0.759 with the following:
Fixes:
  • display the configuration parameters for Z-Wave devices
  • Location and timezone is now correctly set during on boarding for Ezlo Atom
  • Fix the icon for In-Wall switches
  • Fix an issue where a mode was not changed
  • Display energy reports for Fibaro FGR-223 Roller Shutter
For those of you that are Beta testers via the Google platform and want to test the build faster you can enroll at this link, as we’ve changed the tool to distribute the builds - if you haven’t done it already. If you already use the new tool, you’ll receive an app update with v.7.50.758 .
Hi @Ioana
May I ask about this one please.
Should it see and import into a view, all possible Z-Wave parameter settings that a device can have ?
And then allow you to edit those parameters as you require or monitor others for their current value.
On the Vera hubs I think it did that for some devices but not others. We generally had to manually add each Z-Wave parameter setting ourselves that we wanted to change or monitor to see what its current value was set to etc.
