Hello all,
We released a new beta update for Ezlo Linux firmware 2.0.48.2397.3 [production-164] on Nov 29, 2023.
The new update for Ezlo Linux firmware 2.0.48.2397.3 [production-164] for Ezlo Plus and Ezlo Secure controllers contains:
Device integration - new integrations, fixes, and improvements
[2GIG] Fix the representation of the smoke sensor
[Zigbee] Infinite loop on Zigbee library initialization
[2GIG] [Honeywell] Integrate 5800CO Wireless Carbon Monoxide Detector
[2GIG] [Honeywell] Integrate 5800SSI Wireless Shock Glass-break Sensor
[2GIG] [Honeywell] Integrate 5800SMOKEEV Smoke Detector
[2GIG] [Honeywell] Integrate FG-1625 Flush Mount Glassbreak Detector
[2GIG] [Honeywell] Integrate 5821 Wireless Temperature Sensor and Flood Detector
[2GIG] [Honeywell] Integrate 5800SS1 Wireless Shock Sensor
[2GIG] [Honeywell] Integrate 5816 Wireless Door Sensor and Window Sensor
[2GIG] [Honeywell] Integrate 5820L Wireless Slim Line Door Sensor and Window Sensor
[2GIG] [Honeywell] Integrate 5818MNL Wireless Mini Recessed Door Sensor and Window Sensor
[2GIG] [Honeywell] Integrate 5808W3 Wireless Smoke & Heat Detector
[2GIG] [Honeywell] Integrate 5853 Wireless Glass Break Detector
[2GIG] [Honeywell] Integrate 5800COMBO Smoke, Heat and CO Detector
[2GIG] [Honeywell] Integrate 5800PIR-RES Wireless Pet Immune Motion Detector
[2GIG] [Honeywell] Integrate 5800 MINI Wireless D/W sensor
Multichannel devices. Command Set Value is ignored for a short time ( 5 -7 seconds) after a previous try.
Software restriction not activating pincode at the correct time
Cannot set pin code restrictions for door locks
Stelpro Maestro SMT402 integration issue
Stelpro STZB402+ baseboard heater thermostat issue
Ecolink WST-802 is not displayed on Vera App
Integrate Roller Shade device
[Community] Fibaro FGD-212 scene control function not visible in Meshbot
Philio Leak Sensor (PAT02-2C) Integration Issues
Unable to pair Xiaomi Aqara DJT11LM Vibration Sensor
System stability - fixes and improvements
Z-Wave service crashed after a flood from an unknown node
ZWave Service Restart When the Chip Became Unresponsive
[LTE] Improve LTE connection time for T-Mobile and Hologram SIMs
[LTE] AT&T 4G SIMs register in a network faster
[Cameras] More stable work with cameras connected to a hub
[Wifi] Ezlo Plus WiFi connectivity improvements
[Network] Add additional public DNS servers
[Siren] E550 Controller Siren: add default timeout for playback duration
[WiFi] Make intervals between repeatable attempts to scan WiFi networks
[Update Reliability][Filesystem Integrity] Implement an update for the bootloader to enable hub recovery from the USB
[DateTime Management][NTP] Local time is never updated after the firmware start
[MQTT Gateway] Add a hub feature to indicate the hub has MQTT Gateway
[network] wi-fi connection cannot be re-established. Failed to scan LAN (Network Utilities locked in uninterruptible sleep state)
[Plugins][Network] Add socket options: ip-add-membership, ip-drop-membership, TTL
Meshbots
isSunState: sunrise and sunset doesn’t work properly
[EZLogic. Local MeshBot][Anonymous Plugins] hub.scenes.edit: Failed to acquire anonymous plugin
[Plugins][HTTP] Http request skip_security option: skip host domain verification security checks
[Anonymous Plugin] “Failed to acquire anonymous plugin!” while creating a scene
[MQTT Gateway] Support backup create operation
Unable to add “setSceneState” scene block
[Actions] SaveResult: global variable type is modified when an error is saved
[Actions] sendHttpRequest: unable to get a valid response from external API
[Actions] sendHttpRequest: suppress Expect header for PUT/POST requests by default
[Date Node] isDate: daily, weekly, monthly events to plan event time in UTC
[Date Node] isDateRange to plan event time in UTC
[Date Node] isInterval to plan event time in UTC
[Date Node] isOnce to plan event time in UTC
The scene with compareNumberRange for the device group does not run.
[Actions] setItemValue: Multicast optimization ignores the “scale” field
isSunState: Fix sunset/sunrise calculation during the day of DST change
[EZLogic. Local MeshBot] Creation of more than one trigger with device group and item group is not supported - controller errors.
[Stop Meshbot][Triggers] isSceneState: integrate new status “stopped”
Group Operations][Events] Implement isDeviceItemGroup comparison: match event with a device group
VidooAI
[Vidoo] Do not recreate a camera device when the device is renamed
