Beta feedback Ezlo Plus
I am seeing the same thing for a Vision door sensor.
Cheers Rene
Hi @Odysee.
Is it Zwave or Zigbee thermostat ?
Write please model of the thermostat.
That was a Z-Wave device: Eurotronic Spirit
Things seem to be smoothing out, but I do have to say…I miss having browser access. I REALLY miss having browser access. Much easier for firmware management (or at least knowing when there is a firmware update available). Not to mention backup and restore options. This drives me back to the VeraPlus for sure as I couldn’t see myself buying into this without all of the normal functions we’ve always had in the past. Not to mention, I would absolutely refuse to play with any Lua via the phone or tablet. Just my two cents for the moment :slight_smile: I have only tested a few devices on it so far since I don’t want to take everything off of the Vera to use on this as it would crippled a lot of the in-depth scenes I have going. Baby steps :slight_smile:
Hello @TheSaint
Http server will be available in the release after this sprint – July 16th.
Also we are working on our cross browser ui which is working on all our Linux platforms.
It is in our roadmap, planning to have it available in FW by August 20th.
It can be available in browser access.
It would be great if you test with more devices and scenes. Looking forward for more feedbacks from you.
Hi Oleh,
Will you increase the device name, so we might use longer names.
I posted this some time back, but got no reply:
I added the Danfoss living connect, it was named by the system “Living connect Z radiator”, 25 characters, but when trying to rename a device, the MAX is 20, why this limit, and why can the system create longer then we can
Any sneak preview screenshots of the new Web GUI?
I’ve received again a email message that batteries are low. This seems to be right as I see a battery symbol on the thermostats display. So the battery status on the app seems to be wrong.
Thank you for the information. I will test additional devices once I get my hands on a few which should be quite soon hopefully.
I can’t even rename the device right now. It demands timezone to be selected above it, but timezone won’t populate with any options to choose from hah
I wonder how well this compares to the VeraPlus hardware/spec-wise.
How does the location for the astronomical clock get set?
I’ve set the timezone correctly (selected my city). When setting a scene to trigger at “sunset” or “sunset + X”, the scene is triggering approx. 2 hours early.
Timezone is -5 GMT. Local sunset is at 21:39. The “sunset” scene triggered at 19:30.
It’s a known issue that we have to fix on the firmware side. I’ve posted this to the release notes as well:
" Known issues:
  • Issue with incorrect sunset time for scene with different from the default timezone (EST)"
Hi @cokeman, could you please try to connect to your linux firmware/atom using a 3g or another network? Then you should the possibility to change the timezone. The fix is in progress, but it will take some time.
Hi Oleg,
My issue is with the name length
I just installed my Ezlo Plus. I am going to stop the test until their is a firmware update. My controller crashed twice and the App crashed multiple times.
I am using an Iphone 11 Software Version 13.5.1 I am using the latest version of the Vera app
My controller is 90000304
I installed 3 AEON Smart Energy Switches and one Radio Thermostat CT100.
These units were paired to a Vera 3.
Issue 1: Pairing process is confusing.
After selecting the pair process. After the end of the 60 seconds, it says, “The inclusion process stopped.” It doesn’t tell you what to do next and the “retry” is light grayed out. The “retry” should be another color. There should be some indication that you will need to unpair and then pair it again.
Issue #2 Controller shows offline from the web UI.
Issue #3 App crashes
While adding an AEON smart energy switch, it you click retry and don’t wait until the 60 seconds is over, under certain circumstances the app and the controller crashes.
Issue #4 Adding a room. Done light greyed out.
This should be another color.
Issue #5 After adding a Aeon Labs Smart Energy Switch - received an error
“Device failed to communicate.” Nevertheless, I could still control the device.
Issue #6 Remove devices now.
This is unclear what you are suppose to do. Are you suppose to remove the device or are you suppose to try unpairing it and then pair it again.
Issue #7. During CT-100 pairing process app and controller crashed - Celius
Right after the pairing when you are suppose to set the name and room, the controller and the app crashed. Upon restarting, the device was actually paired. In addition, even though the actual device shows fahrenheit, the app shows Celius.
Issue #8 CT-100 shows humidity of 0.0%
Issue #9 Smart Energy switch shows 0.0watt used even when a lamp is on.
Issue #10 When adding a controller, it should ask you the time zone.
My device was set at UTC.
Issue #11 Changing time zone crashed controller
When I changed the Time zone to Vancouver, the controller crashed.
If you want screen shots, let me know.
I
Hi @cokeman , i will check it asap.
Hello @cokeman, i’ve checked with the firmware team, in the next releases we will increase the limit to 30.
I am noticing that scene triggers sometimes fail. I will monitor and report back.
Seems to be when the controller has been power cycled.
The scene is a simple if device on wait 5 seconds turn device off. Now if the plus has been cycled and i attempt to move dimmer slider, the light comes on but the on off button does not turn on and the scene fails to run.
There is also an issue when i attempt to move slider as below
Screenshot_20200707-193852
sonn as i get to about 9% the screen jumps to the below position
Screenshot_20200707-193843
meaning i can not move slider in one movement to say 50%.
This only occurs on the dashboard not the device page.
@ElCid,
Thanks for the description, checking it now.
here is a screen shot of the device with slider on button off and the lamp is on. and the scene has failed to run.
Screenshot_20200707-214458
and here is the alerts from dashboard notice the extra white space thats when scene failed.
Screenshot_20200707-214859
also the alerts from dashboard are missing the text, if i go to alerts page text is there
Screenshot_20200707-215112
Hello, @sdtoddl
Thanks for your feedback.
Just few more questions from my side to have more information about issues.
What was the status of the controller in the app at this time ?
Add more details please how you identified crash of controller ?
What was the led behaviour on the controller at this moment?
Was it with web UI or IOS app ?
Remove devices now - is exclusion process.
If you need, after exclude done, you can start inclusion process again with this device.
We are checking this issue.
