We’ve released a hot fix for Ezlo Linux v.2.0.9.1382.15 for Ezlo Plus controllers:
Hot fix:
- Fixed the issue on Ezlo Plus with losing all devices after the firmware upgrade. This new Firmware version will restore deleted devices but not also scenes, rooms, favourites. These will need to be recreated.
Known issues:
Issue with the Led behaviour in the devices exclusion process where the LED on the controller flashes as if the controller is still in exclusion mode even after clicking the “Exit” button to exit from DPW.
Issue with sensors that can have the status changed to Armed after the upgrade in case there are zwave plugin changes for those specific devices from one FW version to another.
Issue on devices that support Tamper where the broadcasts and notifications generated are opposite to the actual tamper state
Issue on Z-Wave devices with “electric_meter_amper” that is updated only when the hub is restarted. Ampere meter not changing value instantly once pairing a device supporting it (for example pairing a switch and adding some load to it - e.g. connect a bulb)
Issue with incorrect sunrise/sunset time for scene in case the timezone is changed after enrollment. The sunrise/sunset scenes are calculated based on location and for the moment we do not have UI support to change it after enrollment (API is in progress of being integrated in UI)
Issue on Vera Edge where after the first update from Vera FW to the new Linux FW the “Internet” LED is OFF
Issues with some Door Locks, as Danalock V3, that are not added with S2 encryption
Vera Edge Wifi connectifity issues:
- Issues the Vera Edge controller not being able sometimes to connect to a Wifi network
- Issus with disabling wifi interfaces not working on Vera Edge
- Issues with hub.network.get method reporting AP interface as up, even if it is disabled
