We’re excited to release a new update for the Ezlo Linux v. 2.0.3.1159.2 firmware for Ezlo Plus and VeraEdge controllers running Ezlo Linux firmware.
Changes/Improvements:
Changed Wifi AP behaviour (By default AP will be OFF if the controller has internet via ethernet, wifi, mobile and it will be ON if the controller doesn’t have internet). With the upcoming mobile release we will support the possibility to turn ON the AP from UI.
Added changes into the Firmware to support Wifi Onboarding for Ezlo Plus. The UI support for this feature will come part of the next releases.
Fixes:
- Fixed the issue with ezlocast not working in scenes
- Fixed the issues with HTTP API response body containing headers
- Bug fixing on Z-Wave, Zigbee and 2GiG devices
Known issues:
Issue on devices that support Tamper where the broadcasts and notifications generated are opposite to the actual tamper state
Issue on Z-Wave devices with “electric_meter_amper” that is updated only when the hub is restarted. Ampere meter not changing value instantly once pairing a device supporting it (for example pairing a switch and adding some load to it - e.g. connect a bulb)
Issue with incorrect sunrise/sunset time for scene in case the timezone is changed after enrollment. The sunrise/sunset scenes are calculated based on location and for the moment we do not have UI support to change it after enrollment (API is in progress of being integrated in UI)
Issue on Vera Edge where after the first update from Vera FW to the new Linux FW the “Internet” LED is OFF
