Hello all,
We’ve released a new beta update for Ezlo Linux firmware 2.0.33.2116.2 [production-147]
The highlights of this release are
- [Scenes][Date Node] Fixes
- Child devices fixes and improvements
- Virtual devices improvements
- Device integration - fixes and improvements
The new Beta update for Ezlo Linux firmware 2.0.33.2116.2 [production-147] for Ezlo Plus and Ezlo Secure controllers contains:
[Scenes][Date Node] isSunState/after/before: initial state for range events
[Scenes][Date Node] isInterval: Arithmetic exception (core dumped) for isInterval with value 0s
[Scenes][Date Node] AND operator: allow isInterval with multiple isDate, isOnce conditions
[Core] Controller sirens should be turned off when system is disarmed
[Core] Handle room deletion for child devices with own placement
[Core] Add ability to ignore child devices in hub.device.room.set
[Core] Add device.parentRoom field
[CloudStorage] Incorrect params for storage_prepare_upload
[CloudStorage] Logs are uploaded without meta fields
[VirtualHub / SoftHub] ha-luad.log stops logging after trying to configure Mqtt Plugin
[Virtual Devices] Add ability to delete a virtual device from UI
[Virtual Devices] Make the test_plugin be a part of firmware update
[Device integration]
Add support for new Yale Lock product ID
Problems with inclusion of Fortrezz Flood sensor FTS05
Zipato Z-Wave Remote PH-PSR03.US Problem with scenes
Add a 1 second delay to the Thermostat Mode Get command for AC301 in order to update the Mode correctly
