Hello all,
We’ve released a new beta update for Ezlo Linux firmware 2.0.30.2041.2
The highlights of this release are
- improvements and fixes for Meshbots in Ezlogic (Scenes)
- “Database is full” issue fix and other bugfixes
The new Beta update for Ezlo Linux firmware 2.0.29.2027.3 for Ezlo Plus and Ezlo Secure controllers contains:
[Scenes][Conditions] Modify when block for compareNumbers to use (item value) as right part of the comparison. (item vs item, typed expression vs item)
[Scenes] isDate: remove “time” field from weeks and yearWeeks
[Scenes][Conditions] Modify when block for all item-based events to use (item value) as a right part of the comparison. (item vs item, typed expression vs item)
[Scenes] Implement isDeviceState
Getting the “database is full” error makes firmware not working
[http module] http.request() cannot pass certificate
[test_plugin] Add core methods for items and devices testing
