I have some ideas for Vera Plugins, but before I get started I was wondering if there’s a Luup/LUA library available for parsing XML or JSON?
Would be a lot nicer then using the string library as most plugins seems to do now. And I don’t think that writing a JSON or (worse) a XML parser would be a nice project to start learning LUA with ;).
But there’s still no answer on how Vera parses JSON internally. It’s used so widely in the Vera system that you would suspect that LUA has some kind of JSON parser built in.
The MiOS engine, LuaUPnP, is a compiled C++ executable. It presumably has its own JSON and XML libraries, which it doesn’t expose to the Lua interpreter that is also built into the executable.
It’s still a pain for as long as apps.mios.com doesn’t let two different plugins include a file with the same name. Renaming it to be different for each plugin doesn’t scale and wastes storage.
Apps.mios.com is evolving towards a package management system. Package management is hard to do properly. before apps.mios.com evolves further, give some serious thought to using the one that comes with OpenWrt.
Apps.mios.com is evolving towards a package management system. Package management is hard to do properly. before apps.mios.com evolves further, give some serious thought to using the one that comes with OpenWrt.[/quote]
Totally agree… Vera needs to leverage more open source community projects, AND allow use to use them in a supported way.
I hope you can get a JSON parser working. XBMC uses JSON notifications and I’d love to have the Vera integrate with XBMC.
Chixxi said he was working on an XBMC plugin, which would require a JSON parser, so I suggest you ping him to see if you can collaborate.
@ Everyone
Don’t be afraid to contact MCV directly. I suspect the more coders we have reaching out to MCV directly (phone, email ,etc) to get help building something that can benefit the entire community, the more they might be willing to help. The key here is to explain HOW what you are doing can benefit the entire community, and make their lives easier in the long run.
Example: “I’m building a JSON receiver/parser for the Vera and would like a small bit of assistance. I promise not to take up much of your time if youd be kind enough to assist. This plugin will benefit the entire community as there are many apps that communicate using JSON and the list is growing daily as it has become the defacto communication standard for apps. Having this available to the community will allow Vera to integrate with apps like: ”
I write a plugin that use an external json parser module (come from here json/json.lua at master · luaforge/json · GitHub ).
Maybe my plugin could check (in /usr/lib/lua) if this module exists and download it during the first start ?!
This way each plugin that use this module will find it …
Is there a better solution ?
Just checking if Lua CJSON has been added to the vera3? I am trying to run some test code
-- Module instantiation
local cjson = require "cjson"
local cjson2 = cjson.new()
local cjson_safe = require "cjson.safe"
-- Translate Lua value to/from JSON
text = cjson.encode(value)
value = cjson.decode(text)
and I am getting an error that the filed is nil so my guess is that it has not been added, but it could be user error, so I thought I would check before giving up.
for my plugins, I got around the lack of json parser by using the following function…
function decode_json(json)
if (not json) then
return nil
local str = {}
local escapes = { r='\r', n='\n', b='\b', f='\f', t='\t', Q='"', ['\\'] = '\\', ['/']='/' }
json = json:gsub('([^\\])\\"', '%1\\Q'):gsub('"(.-)"', function(s)
str[#str+1] = s:gsub("\\(.)", function(c) return escapes[c] end)
return "$"..#str
end):gsub("%s", ""):gsub("%[","{"):gsub("%]","}"):gsub("null", "nil")
json = json:gsub("(%$%d+):", "[%1]="):gsub("%$(%d+)", function(s)
return ("%q"):format(str[tonumber(s)])
end)
return assert(loadstring("return "..json))()
it is called like:
local data = decode_json(json_string)
The returned value in the “data” variable is a lua table containing the key/value elements in the json string. Be aware that any elements in the json string that evaluate to the json null value are not translated into the data table, so value checking is required.
If programming for UI7, all versions have included the dkjson library…
local JSON = require("dkjson")
local toencode = JSON.encode(lua_table)
local todecode =JSON.decode(json_string)
[quote=“nullx8, post:16, topic:171469”]any idea whats wrong with that:
if (luup.version_major < 7) then
local endecoder = require("akb-json");
else
local endecoder = require("dkjson");
that somehow gives me a
LuImplementation::StartLua skipping device 245 implementation valid 1 <0x2b6a5680>
[/quote]
You are defining the endecoder variable inside the if/then/end… it is scoped for use only inside that statement… after the if/then/else/end it goes out of scope and causes a crash when you try to use it. use:
local endecoder = nil
else
