After I successfully got my Powermax Pro alarm hooked up to Vera (with excellent help from this forum), I’m now looking into how I can get events (specifically PIR sensor events) out of Vera and into Domoticz.
I’m currently fumbling my way with : Vera → OpenHAB w/MIOS binding > MQTT > Domoticz. But this is quite a lot of stuff to set up for something very simple…
What is the simplest way to get Vera to do a simple HTTP Post upon a device status change?
If all you want to do is send an http request, you can do it much simpler by (for example):
function RunExtVeraScene(scnnum)
luup.inet.wget("http://192.168.0.51:3481/data_request?id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=" .. scnnum, 5, "", "")
The above code is what I use to send an http request from one vera to another (different UIs, so they cant be bridged).
(Then when I want to run scene 7 on the other vera I just write:)
