@slapfrost
Thank you for the feedback.
During my time on the phone with the Tech, we attempted to exclude/include the FE599 lock a couple times. I also repeated the process a few times after getting off the phone with the Tech. Each and everytime, the range extender was not used for the exclusion/inclusion process. The Ezlo Plus controller was placed within 2 feet of my lock for this process.
The controller would include the lock and it would show up in the mobile app as a “Allegion Door Lock” . But the App is unable to control the lock. It does not show battery life, I can not remotely open/lock the door lock or add any user codes. The lock does not function at all on the Ezlo controller.
I have had this lock for about 5 years and it worked flawlessly when I had the Vera Edge controller, But unfortunately that controller stopped working, so I switched to the Ezlo Plus controller a little more then a year ago, and I have been dealing with this same issue of the lock not functioning with the Ezlo Plus ever since.
Last year, I was informed that the FE599 lock was tested and integrated into the Ezlo Plus controller system. But, I could never get it to work on my end. I have several other Z-Wave devices, such as window/door sensors, thermostat, water leak sensor, smoke detector, etc. They all work fine on the Ezlo Plus, it is just the Schlage FE599 that will not work with the controller.
At this point, I am throwing up the white flag and giving up on the process. I dont know if it is the Ezlo system that is not compatible with the lock, or perhaps the lock is no longer working properly and so it will not integrate with the controller properly. But, in either case, I am done trying to get it to work, it has been over a year of frustration. I have decided to just purchase a WiFi smart lock that works independently of the Ezlo system and Use my Ezlo controller for all my other devices.
Thank you for you assistance.
Thomas Rickey
