Can you clarify a few things:
How is your local network (LAN) response to other local devices?
The only LAN use here is when I use email, online banking, etc, all faster connect times.
How is your Vera connected to your LAN and router (wifi, cabled, via a switch)?
Direct Ethernet Cable
Have you tested external connection via either cpui5.mios.com, cp.mios.com or through getvera.com? (This would confirm the latest registered IP address of your Vera)
The cpui5.mios.com connected faster but was still slow.
https://fwd2.mios.com/remote/1.5.622-en/?token=4cca....&PK_AccessPoint=…
When I entered cpui5.mios.com it came up requesting that I pick a unit and also stated ?Unassigned units in the same network: None?
It showed my Account #300…, and IP:192.168.1.152 and when selected it was a slow connection but still faster than entering 192.168.1.152 like in the past which redirected to http://192.168.1.152/cmh/ which basically stalled for over a minute and finally connected but was still loading data for over 10 minutes when I cancelled it!
The cp.mios.com connected faster than using http://192.168.1.152/cmh/ but was still slow
https://fwd2.mios.com/remote/1.5.622-en/?PK_AccessPoint=.....&token=1a…
The getvera.com loaded fast but was all the advertising about Vera and I never got through to my account.
How have you configured the ip allocated to your Vera (static, reserved or DCHP)?
I don?t understand this
Have you logged on to your switch or router to confirm the current IP address of your Vera?
When I entered cpui5.mios.com it showed my Vera?s IP as 192.168.1.152
Do you have a iPhone or Android, (So you can download Fing and confirm the IP address of your Vera)?
I have an Android Smartphone: Samsung Galaxy Note 2
The error can either be a local network issue such as an incorrect (previously Vera allocated IP that is now redundant), IP conflict, your Vera is not connected or a Vera issue. But normally revolves around the IP address.
If you are connected locally over your LAN and directly to your Vera, internet connection speed is not the issue and does not impact on the rendering of the dashboard.
Edit: this is not a computer or browser issue either, it is a connection issue.
Last test is to connect computer direct to on of your Vera LAN ports. And then try 192.168.81.1 and see if this work with a direct connection. This is more learning to identifying Vera specific issues.
Edited by: mcv.vlad
I removed private information from this post. Please take better care in the future to avoid leaving the fwd.mios.com url on any public place.
Vlad
