Currently I have Pella and for between the glass solar and “roomside” battery roller blinds, the solar blinds are hard to beat in between the glass, but I am addressing this to “roomside” curtains.
I have to add blackout curtains to my daughter’s room, I could use Pella but my wife wants curtains over roller blinds. Of course I just like to automate everything.
What do you recommend and what bridge device do they use?
Does Pella use Somfy RTS or their own 433MHz radio? Somfy is currently releasing a battery powered curtain/drape motor, so it uses Somfy RTS radio for control. It offers a detachable battery pack that you can even have an extra one charged and swap them out if needed, or plug-in overnight to charge and give you 90 days or more depending on the curtain/drape weight.
I have QMotion’s battery powered curtain rod, which is very cool, but my version is not integrate-able with my QConnect, although should be integrate-able with their most recent QSync (all 433 mhz, but QConnect and older blinds and older QSync are different modulation).
They now have a zigbee 1.2 HA version, which SHOULD be integrate-able directly with the VeraPlus, no other controller required, but I haven’t seen anyone try it yet. Ordinarily I would be an early adopter, but I am still Vera3/UI5 - AND I am waiting for QMotion to release their Z-wave motors and plan to retro-fit all my QMotion roller blinds and curtain rod to z-wave once available.
Good question, not sure, I can probably send pictures of their motor. I know they OEM it. Pella’s hand held remotes are nice, to communicate with ZWave they require a bridge. The bridge is first added to ZWave controller, then you add in the blinds to the bridge. The blinds can pair to up to 6 devices I believe?? So you can have the remote or more than one remote and the ZWave bridge (counts as a remote to the max pairing limit) to one blind.
Had to make a cable by shrink wrapping a old phone cable to the mono price zwave controller.
The Y cable is to split power from the battery box, It takes 8 AA batteries to deliver the 12V to the motor and the whole thing can be set on the wall or the curtain motor. It works perfectly. I have 3 curtains automated that way. The thing I like most is that they can still be operated manually since the motor disengages when not working.
