@Bulldoglowell: Did you try Control Cube? It has built-in integration with Sonos, XBMC and Global Cache (without vera plugins and directly on the app). There isn’t any zwave app in the market that has these features.
I have also personally installed and tested the app in more than a dozen 5,000+sqft homes over the past 3 months (I install VERA for a living). The app works smoothly and reliably Try it and let me know what you think.
[quote=“hadiesper, post:21, topic:177156”]@Bulldoglowell: Did you try Control Cube? It has built-in integration with Sonos, XBMC and Global Cache (without vera plugins and directly on the app). There isn’t any zwave app in the market that has these features.
I have also personally installed and tested the app in more than a dozen 5,000+sqft homes over the past 3 months (I install VERA for a living). The app works smoothly and reliably Try it and let me know what you think.[/quote]
@jimpapa: thanks for the feedback. Yes I am the author and seller of the app
About the multiple Vera’s, yes and there is no limit. I have tried 4 Vera’s with around 30 devices each. But theoretically and based on the architecture you should be able to support an unlimited number. The network load of supporting multiple Vera’s is a single http GET request every 30 seconds to each Vera so the load on the app is negligible.
With regards to Sonos, xbmc and GC. The app does not actually communicate with any of them on app launch nor on a polling interval. It just initiates contact when you click on a specific Sonos icon. This mean that theoretically you can have hundreds of Sonos zones and hundreds of XBMC and Global Cache devices and the app would not be affected at all in terms of performance or stability.
Ditto for Homewave. Not the right App for something “Toaster” level…But most of us that use Vera want something that’s flexible and configurable. Do a search for some of the threads showing examples of some of the screens folks have set up.
[quote=“hadiesper, post:25, topic:177156”]@jimpapa: thanks for the feedback. Yes I am the author and seller of the app
Sent from my iPhone using Tapatalk[/quote]
Probably a dumb question - you mention vera 2 or 3 but not lite - Is that an issue? Have you had any issues with any of the apps (nest, security) ?
@rgreenpc: totally a valid question. Vera lite is supported. I’ll add it to the list on the website today.
I have tried the app with nest and ecobee. You sometimes get a timeout error because of delays in communication with their servers but the commands still always go through.
As for security, you can put door and motion sensors. You can display their status and Arm/disarm. But if you mean integration for another security system plugin in vera. We don’t have that in yet. What did you have in mind?
You are right, currently we support zwave devices and scenes. So you should be able to arm/disarm the panel with a scene on control cube that runs LUUP code to control the security panel but you won’t be able to see status of the panel.
Currently the supported devices are:
Vera Binary light (switch)
Vera Dimmer
Vera Thermostat
Vera Door or motion sensor
Vera Scenes
HTML webpage (which you can use to view a webpage of a camera or any other 3rd party product that has an HTML UI)
Sonos
Xbmc
Global cache(version 1.2 of the app)
Also, we should be releasing an iphone version in about 2 weeks.
Using HomeWave I do not have access to Vera from other places,
Using local network it wors well but I can not connect to vera using it using internet.
Can anyone help me through this?
