https://www.amazon.com/BeSense-Ceiling-Motion-Detector-SmartThings/dp/B01LY1IZEX
after adding this device it creates 2 devices, a Generic IO and a _Motion Sensor does anyone have the correct configuration for this device
does anyone know how to get this configured as one device? or how can I find out what type of attributes are from the first endpoint
I usually hide the child and change the master. Instructions’re here on the old forum:
http://forum.micasaverde.com/index.php/topic,51782.msg380669.html#msg380669
blacey
3
Got it correctly configured
the child device has an option that say no_child_sync
set that to 0 - do not delete the child device you have to stop the child endpoint from the main device
local devnum = *Main Device Number*
local endpoint = *Endpoint*
luup.attr_set ("device_json","D_MotionSensorWithTamper1.json",devnum)
luup.attr_set ("device_file","D_MotionSensor1.xml", devnum)
luup.attr_set ("device_type","urn:schemas-micasaverde-com:device:MotionSensor:1", devnum)
luup.attr_set ("category_num","4", devnum)
luup.attr_set ("subcategory_num","3", devnum)
luup.attr_set ("no_child_sync","3", endpoint)
luup.attr_set ("altid","", endpoint)
luup.attr_set ("id_parent","", endpoint)
luup.variable_set("urn:micasaverde-com:serviceId:ZWaveDevice1", "NoChildren", "1", devnum)
luup.variable_set("urn:micasaverde-com:serviceId:HaDevice1", "ChildrenSameRoom", "0", devnum)
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "Reload", {}, 0)
Im working on getting rid of the endpoint
EDIT: under settings uncheck embeded reload luup and now u can delete the child device
