All my devices seem to be nicely configured and work well except that icons from the batterystatus are always grey from all my batterie operated devices.
I tought they have to be green ??
Greetzz !
Greetzz !
I believe that means that the battery level has not been reported by the device. What type of device are you using?
Sometimes they take a while to report and they get marked like that by Vera until she next successfully gets an update.
I had the same problem with a FortrezZ Water/Freeze sensor. I had placed it in a far corner of the house. The battery indicator on MiOS was gray…and I noticed the temperature reading never changed.
I realized that Vera was not receiving the sensor’s updates, perhaps because it was too far from the nearest Z-Wave plug or device that could relay the signal. So, I added two Z-Wave switch outlets near the FortrezZ and, within hours, MiOS was showing the proper temperature and battery level.
