Hello Massalia,
It is Vera 3 @1.5.408. All other aspect are function as detailed in the roadmap.
Hello Massalia,
@thbodart itâs not yet validated, probably tomorow.
If itâs still not working for you, could we arange a âlive debugâ session, if youâre in france ?
Bonjour Massalia
Ăa fonctionne. Merci
A quoi servent les fichiers push09 ?
A rien, je me suis trompé de fichier en publiant. :![]()
I made a mistake when pusblishing the file (Wrong Version), now itâs corrected.
@Brientim thanks for your help.
Hello Massalia
I donât know from where comes the problem but in the iOS application Automator, the color of the main battery icon stay blue and donât change.
Have a nice day
Thierry
I have six devices, all recognized, but the icon stays blue. What am I doing wrong? Running a Vera Lite with 06 version of the plugin
Your icon have the right color in the vera dashboard, and stay blue in Automator ?
You have to launch a check, either with a scene or with luup code, then the icon will reflect the result.
Thx, that did the trick
This works great, thanks to the developers!
Sorry Massalia, missing the reply.
Yes, the icon have the right color (red) in the vera dashboard, and is blue in Automator.
Could you make the windows of the plugin bigger or change the order of the text because I only see CHK - 05:00 ⊠and the date is missing in the simple vue.
Bonnes fĂȘtes de fin dâannĂ©e
Hi salut Massalia
Thx for this plugin.
Once itâs checked by a scene for the first time, does it check automatically then ? Or do we have to plan a daily check scene ?
Thx
Hello milillicuti.
You need to schedule the scene to run perodically, daily weekly etc
Thanks so much for this plugin - it allows me to delete all the triggers I had set for my many battery devices. The one thing that was not clear to me on installation was the need to schedule a âCheckâ to run regularly in order to populate the display and icon correctly⊠perhaps there was some installation note or documentation that I missed? Anyway, reading through this thread eventually put me right.
I did just wonder why a time interval for doing the check was not incorporated into the plugin, but doing it this way is very Vera-like (or should I say MiOS-like), and once you know that then all is well.
Merci beaucoup.
AKB
@Brientim, akbooer
I did just wonder why a time interval for doing the check was not incorporated into the plugin, but doing it this was is very Vera-like (or should I say MiOS-like), and once you know that then all is well.
For now you need to schedule a call to the check action to update status and check battery state, but i can incorporate it in the plugin as an option for next release.
Hello Massalia,
It makes a lot of sense to incorporate auto updating into the core app and allow the user to set the interval in an variable.
As I have regimented in my battery replacements all together on the same day in the past, this may in the future break this habit and save se money.
Thanks again.
[quote=âMassalia, post:37, topic:172778â]@Brientim, akbooer
For now you need to schedule a call to the check action to update status and check battery state, but i can incorporate it in the plugin as an option for next release.[/quote]
Yes, this would be very usefull ! One less scene ![]()
Massalia, can you have a look at this post ?
http://www.touteladomotique.com/forum/viewtopic.php?t=9533&p=77523#p77523
Psykokwak use a function to check is the device has low batt or IS active (ping function). This is very usefull for users who have Oregon Scientific sensors through RFXTRX 433.
Would it be possible to add it to your plugin ?
The first column would be âLow battery or unreachable devicesâ.
Thank you very much for your work. Merci Ă toi.
Good Idea.
Iâll probably had a specific event, and a configuration option for unreachable device notification, iâll try to release this, in next release with the auto-check option.
Il faudrait aussi que je fasse un post sur le forum tld pour publier mes plugins ;-)Best Home Automation shopping experience. Shop at Ezlo!
