I’ve been trying to set up a scene in which a window/door sensor is tripped and the strobe/alarm turns on. I’m very new to this and I’m sure this is probably a very simple configuration. I would appreciate if someone could give a step-by-step setup instruction as I have ran out of ideas. I’m excited with my Vera and extremely frustrated with the unfriendliness of the system setup and the lack of proper installation/setup guide by MCV. Anyway, if you would be kind enough to give me a hand on this one I would greatly appreciate.
Thanks a lot!
First of welcome to the forum. See here for getting started on how to create a scene:
http://forum.micasaverde.com/index.php/topic,13305.msg98962.html#msg98962
Thanks, Garret! Your help is much appreciated.
Here is what I did:
- Create a scene called “Set Alarm”
- Selected the strobe in the device tab and set it to “ON”
- IN the triggers tab, I selected a window sensor as the trigger
- Set it as follows:
Edit trigger
Device: #43 Maya’s
What type of event is the trigger?: A sensor (door/window/motion/etc.) is tripped
Name for this trigger: Window alarm went off
Tripped Device is not tripped
When I run this scene, the strobe goes on immediately even thought the sensor has not been tripped yet.
Any suggestions?
Thanks!
I believe you need “device IS tripped”…
