Hi
I would like to add basic support for my Denon receiver to AutHomation, what would I need to do the add the following: -
Volume
On/Off
Input Selection
Are any of these supported currently and what are the upnp specs (Media Controller plugin) and if these are supported what is the device type?
[quote=“zoot1612, post:1, topic:182285”]Hi
Volume
On/Off
Input Selection
Are any of these supported currently and what are the upnp specs (Media Controller plugin) and if these are supported what is the device type?[/quote]
Right now there is not direct support for av type devices or ir gear. I have on my list to support the generic ir device with some limited controls. The app does support custom intents for the following services you listed. In order to add support for the common / standard types in your app here is the following suggestions:
