So this is probably a super basic question for you but I just can’t figure how to make it work correctly with Pleg… I have a switch that I want to turn on at a specific time… (that part works
) but I also want it to shutdown 4 hours after… Taking in consideration that the Vera unit might reboot in between for whatever reason… So I created a schedule called “AirExchange_ON” as below with a Offtype Interval of 4 hours :
I also created the condition (not sure to understand it…):
and the following logic action:
Doing so, the switch turns on but not off after 4 hours …
So I guess I’m misunderstanding the “Offtype Interval” …
Should I instead add an interval in the logic action as follow ?
Would that resist a vera reboot and still turn off the switch after the initial 4hour period ?
Thanks ![]()
