Hi
I have some programming background. I would like to modify the Json file for at least one object.
As if now, I was not able to locate the working file the the device in particular.
The file is D_HVAC_ZONEThermostat1.json. I was able to find the location for the original version (/etc/cmh-lu) but I assume this is the file that is used as a repository.
Any one can share the location of the file(s) (XML as well) that are used by the system?
Also, if there is a 'all you need to know to start ’ your own code, I would appreciate.
Thanks in advance
Daniel
