it’s a great plugin ![]()
Is it possible to draw a BarGraph ?
Nobody can help me ? :-[
Hi
Bargraph is possible as per the example attached:
Oh it’s great … but how do you do this ? with what parameter ?
Hi
I am answering using my phone so i can not check the website.
You can change this in the configuration section. The same where you enable logging for each variable. There you also see the type of chart. By default spline is selected but you can choose area for example. If you can not find it please let me know and i will send a screendump
Ok it works thank you
