Just wanted to let folks know the Aviosys 9100A works with VeraLite. I had a couple old ones sitting around so hooked up a camera, manually configured camera (://192.168.xxx.xxx/usr/yoics0.jpg for camera 1). It sees the jpg and displays it, but in interface doesn’t show. Once you specify the device_file under advanced tab as “D_DigitalSecurityCamera1.xml” Everything pops up and works fine.
This Aviosys 9100A has the Yoics 9100a firmware and not the default, but they are similar so either should work once the correct jpg directory is specified. ;D
These are fairly inexpensive so make an easy addition of up to 4 cameras to your Vera
