Are these XSLTs still hosted somewhere. Clicking on the links takes me to a private repository that is not accessible.
Also, since the SQ Remote software isn’t working with box.net is there another way to get any my sq blaster dev files? Thanks!
I have a Sony Bravia TV that I believe will only work with UEI codes.
I’m in the process of moving all my Plugins to a new home, outside of code.mios.com, so these files are offline.
In the meantime, you can use the attached/latest version XSLT/Transformation files for SQBlaster. I’ve renamed them from [tt].xsl[/tt] to [tt].txt[/tt] to match the forum rules for attachments.
Excellent, thank you!
What about another way to access the blaster dev file since the box.net backup isn’t working right now. Any ideas?
No idea, I haven’t had to mod my dev_*.xml files in eons.
There’s another thread where this is being discussed.
Is their anyway the Master Member can help me with having Vera connect thru my existing SQ Blaster IR devices thru existing configuration. I am not understanding how to do this. I have Vera3 with UI5 and have my existing SQ Blaster plugin installed just don’t know the next steps, I have read other threads but not clear to me.
