I have two Vera Plus UI& (1.7.2044) units with AutoVera running and it works fine. The only problem I’ve seen so far is that for some reason it reports the number of Android Devices as “temperature 4”
Same here. It reports the number of devices as temperature. So instead of saying “Number of Devices 8” it says “temperature 8”. It still works as it should but quite annoying.
