Automation problem with Sunrise/Sunset
I just added a second veralite controller to my system. It is controlling a zwave switch which I would like to turn on at sunset and off at sunrise. I have set up a schedule for each event. However, the sunrise event is triggering at around midnight and the sunset is triggering at around 10 in the morning.
For background, when I was trying to figure out the cause, I discovered that my timezone was incorrect on the veralite. I changed it to the correct time zone, but this did not correct the problem. I then tried rebooting the vera unit to no effect. Finally, I tried deleting and recreating the schedule. Still not working.
I had this working just fine on my original controller.
Any thoughts would be appreciated.
You must also set the location of your Vera.
It uses the location and the timezone to decide when sunrise and sunset are for your location.
I guess that should have been obvious. Thanks for your reply.
