Ok, here is my finished code, a bit rough - but it works and makes a call to the ATEN hdmi matrix for its status, extracting the first 5 lines. - which it then translates and presents the resulting information into the UI5 messaging/task window. (Once again thanks to @akbooer for the basis of this workflow)
[code]function send_command_to_hdmi_matrix(…)
local socket = require(“socket”)
host = “192.168.1.147”
c = assert(socket.connect(host, 4002))
c:settimeout(5)
– read matrix status
local sres, serr = c:send(string.char(…))
print(“Send:”, sres, serr)
local data1, rerr1 = c:receive(‘*l’)
local data2, rerr2 = c:receive(‘*l’)
local data3, rerr3 = c:receive(‘*l’)
local data4, rerr4 = c:receive(‘*l’)
local data5, rerr5 = c:receive(‘*l’)
local line1 = string.match (data1, “%u%a+%s%a+”) or “error”
local line2 = string.match (data2, “%o%d+%s%i%d+”) or “error”
local line3 = string.match (data3, “%o%d+%s%i%d+”) or “error”
local line4 = string.match (data4, “%o%d+%s%i%d+”) or “error”
local line5 = string.match (data5, “%o%d+%s%i%d+”) or “error”
print (“line 1:”, data1, rerr1)
print (“line 2:”, data2, rerr2)
print (“line 3:”, data3, rerr3)
print (“line 4:”, data4, rerr4)
print (“line 5:”, data5, rerr5)
print (“” …line1)
print (“” …line2)
print (“” …line3)
print (“” …line4)
print (“” …line5)
c:close()
return line2, line3, line4, line5 – return the result
local function interpret_reply_from_hdmi_matrix(status)
local message = {
– error
[“error”] = “Something else happened, it likely failed”,
– Output 1
[“o01 i01”] = “Ouput 1 is showing input 1”,
[“o01 i02”] = “Ouput 1 is showing input 2”,
[“o01 i03”] = “Ouput 1 is showing input 3”,
[“o01 i04”] = “Ouput 1 is showing input 4”,
– Output 2
[“o02 i01”] = “Ouput 2 is showing input 1”,
[“o02 i02”] = “Ouput 2 is showing input 2”,
[“o02 i03”] = “Ouput 2 is showing input 3”,
[“o02 i04”] = “Ouput 2 is showing input 4”,
– Output 3
[“o03 i01”] = “Ouput 3 is showing input 1”,
[“o03 i02”] = “Ouput 3 is showing input 2”,
[“o03 i03”] = “Ouput 3 is showing input 3”,
[“o03 i04”] = “Ouput 3 is showing input 4”,
– Output 4
[“o04 i01”] = “Ouput 4 is showing input 1”,
[“o04 i02”] = “Ouput 4 is showing input 2”,
[“o04 i03”] = “Ouput 4 is showing input 3”,
[“o04 i04”] = “Ouput 4 is showing input 4”,
return message[status] or “Unexpected status code received”
– here’s the message in the UI5 panel
local function present_results_of_hdmi_matrix_interaction(result)
print (result)
local handle = luup.task(“” … result, 1, “ATEN HDMI Matrix”, -1)
luup.call_delay(“clearTaskMsg”,5,handle)
function clearTaskMsg(strHandle) – this HAS to be non-local for call_delay to work
luup.task(“”,4,“”,tonumber(strHandle))
– here’s the main ‘workflow’
local l1, l2, l3, l4 = send_command_to_hdmi_matrix(0x72,0x65,0x61,0x64,0x0d,0x0a)
local message1 = interpret_reply_from_hdmi_matrix(l1)
local message2 = interpret_reply_from_hdmi_matrix(l2)
local message3 = interpret_reply_from_hdmi_matrix(l3)
local message4 = interpret_reply_from_hdmi_matrix(l4)
present_results_of_hdmi_matrix_interaction(message1)
present_results_of_hdmi_matrix_interaction(message2)
present_results_of_hdmi_matrix_interaction(message3)
present_results_of_hdmi_matrix_interaction(message4)
print (l1, l2, l3, l4)
print (message1, message2, message3, message4)[/code]
Here is the Lua Test output, happy to hear any recommendations on code improvement - Im also looking to see if I can create a basic visual representation of each output/input e.g [1] [2] [1] [1]
[u][b]LuaTest 1.7[/b][/u]
Lua file: /nas/luatest/aten_matrix-read-v2.lua
Results
No errors
Runtime: 124.0 ms
Code returned: nil
Print output
Send: 6
line 1: read Command OK
line 2: o01 i02 video on audio on CEC off
line 3: o02 i01 video on audio on CEC off
line 4: o03 i01 video on audio on CEC off
line 5: o04 i01 video on audio on CEC off
Command OK
o01 i02
o02 i01
o03 i01
o04 i01
o01 i02 o02 i01 o03 i01 o04 i01
Ouput 1 is showing input 2 Ouput 2 is showing input 1 Ouput 3 is showing input 1 Ouput 4 is showing input 1
Code
1 function send_command_to_hdmi_matrix(…)
2 local socket = require(“socket”)
3 host = “192.168.1.147”
4 c = assert(socket.connect(host, 4002))
5 c:settimeout(5)
6 – read matrix status
7 local sres, serr = c:send(string.char(…))
8 print(“Send:”, sres, serr)
9 local data1, rerr1 = c:receive(‘*l’)
10 local data2, rerr2 = c:receive(‘*l’)
11 local data3, rerr3 = c:receive(‘*l’)
12 local data4, rerr4 = c:receive(‘*l’)
13 local data5, rerr5 = c:receive(‘*l’)
14 local line1 = string.match (data1, “%u%a+%s%a+”) or “error”
15 local line2 = string.match (data2, “%o%d+%s%i%d+”) or “error”
16 local line3 = string.match (data3, “%o%d+%s%i%d+”) or “error”
17 local line4 = string.match (data4, “%o%d+%s%i%d+”) or “error”
18 local line5 = string.match (data5, “%o%d+%s%i%d+”) or “error”
19 print (“line 1:”, data1, rerr1)
20 print (“line 2:”, data2, rerr2)
21 print (“line 3:”, data3, rerr3)
22 print (“line 4:”, data4, rerr4)
23 print (“line 5:”, data5, rerr5)
24 print (“” …line1)
25 print (“” …line2)
26 print (“” …line3)
27 print (“” …line4)
28 print (“” …line5)
29 c:close()
30 return line2, line3, line4, line5 – return the result
31 end
32
33
34 local function interpret_reply_from_hdmi_matrix(status)
35 local message = {
36 – error
37 [“error”] = “Something else happened, it likely failed”,
38 – Output 1
39 [“o01 i01”] = “Ouput 1 is showing input 1”,
40 [“o01 i02”] = “Ouput 1 is showing input 2”,
41 [“o01 i03”] = “Ouput 1 is showing input 3”,
42 [“o01 i04”] = “Ouput 1 is showing input 4”,
43 – Output 2
44 [“o02 i01”] = “Ouput 2 is showing input 1”,
45 [“o02 i02”] = “Ouput 2 is showing input 2”,
46 [“o02 i03”] = “Ouput 2 is showing input 3”,
47 [“o02 i04”] = “Ouput 2 is showing input 4”,
48 – Output 3
49 [“o03 i01”] = “Ouput 3 is showing input 1”,
50 [“o03 i02”] = “Ouput 3 is showing input 2”,
51 [“o03 i03”] = “Ouput 3 is showing input 3”,
52 [“o03 i04”] = “Ouput 3 is showing input 4”,
53 – Output 4
54 [“o04 i01”] = “Ouput 4 is showing input 1”,
55 [“o04 i02”] = “Ouput 4 is showing input 2”,
56 [“o04 i03”] = “Ouput 4 is showing input 3”,
57 [“o04 i04”] = “Ouput 4 is showing input 4”,
58 }
59 return message[status] or “Unexpected status code received”
60 end
61
62 – here’s the message in the UI5 panel
63 local function present_results_of_hdmi_matrix_interaction(result)
64 print (result)
65 local handle = luup.task(“” … result, 1, “ATEN HDMI Matrix”, -1)
66 luup.call_delay(“clearTaskMsg”,5,handle)
67 end
68
69 function clearTaskMsg(strHandle) – this HAS to be non-local for call_delay to work
70 luup.task(“”,4,“”,tonumber(strHandle))
71 end
72
73 – here’s the main ‘workflow’
74 local l1, l2, l3, l4 = send_command_to_hdmi_matrix(0x72,0x65,0x61,0x64,0x0d,0x0a)
75 local message1 = interpret_reply_from_hdmi_matrix(l1)
76 local message2 = interpret_reply_from_hdmi_matrix(l2)
77 local message3 = interpret_reply_from_hdmi_matrix(l3)
78 local message4 = interpret_reply_from_hdmi_matrix(l4)
79 present_results_of_hdmi_matrix_interaction(message1)
80 present_results_of_hdmi_matrix_interaction(message2)
81 present_results_of_hdmi_matrix_interaction(message3)
82 present_results_of_hdmi_matrix_interaction(message4)
83
84
85 print (l1, l2, l3, l4)
86 print (message1, message2, message3, message4)
