Hi All,
I want to be able to get sensors / lighting triggers working well and wanted to see people’s thoughts / advice.
Some background:
I use Mcontrol – vera is the controller. Currently my macros (scenes) are mostly in Mcontrol. Current set up is: sensor triggered> macro kitchen light on for 5 minutes runs + also stops any existing instance of the “off” macro to stop macro. The “off” macro is tripped when the sensor is off.
The aim:
To have a lights stay on in the kitchen if you are in there – e.g motion is constantly detected.
The current issue:
Lights often turn off then on again instantly but I want to achieve the outcome that they stay on without going off until such time as no motion is detected after say 5 minutes.
Possible solution:
Moving a similar set of commands directly to Vera as Scenes perhaps? Thus perhaps avoiding the use of Mcontrol as not really needed. But how best to implement?
Looking forward to what people do as I can’t be the first to do this setup
Many thank in advance all.
- LightsOn
