Fairly simple stuff… I have some outdoor lights which follow a motion sensor when it’s dark. Two groups - one for detecting motion at sunset (for turning the lights ON) and a second group to check for no motion after a few minutes (for turning the lights OFF). Works perfectly.
The problem I’m trying to solve though is that I also want to control the lights manually for a sustained period, on demand. I need a way to ignore the motion sensor when this is true.
I’m hoping there is a way to do this in the same Reactor logic but I haven’t been able to figure it out.
PS - I could probably do this with DelayLight but again, I’m hoping I can tackle the problem inside the same/existing Reactor sensor.
Why not have a virtual switch control the light manually and use that same virtual switch as condition in your logic? Conditions will not trip unless virtual switch is off. (0).
This will probably only work if you use the vera interface or another to control the virtual switch manually vs the physical switch since if you trigger the virtual switch on/off via a physical switch button press it will break the automated routine since the automated routine will also trigger the virtual switch.
I just watched your delayLight emulator video. Thanks heaps (loving the vids by the way - very helpful!).
I’m gonna give it a try for myself when I get some time this weekend. The way you are tracking the state of the switch was definitely the piece I was missing when trying to work out the logic myself.
Cheers.
