First place i saw this was in the openluup installation, where i got hundreds of duplicates over night.
Now i turned on auto create on my vera to add a switch, and the switch came up immediately with two devices, the second with a “1” on the end of the name.
Had to reset my RFX completely, and did a reinstall with 1.96 using 433e with Type 1 FW.
This issue reoccurred, so I suspect that OpenLuup and Vera doesn’t handle the way RFX Plugin checks if the sensor is already there?
@tinman, How exactly does the plugin work in terms of checking if the sensorID is already in the system? Or can you point me to the code that handles it?
I noticed that the AltID and name is identical on all 3-15 instances the plugin made…
-- Creation of new child devices
local autoCreate = (getVariable(lul_device, tabVars.VAR_AUTO_CREATE))
local tableNewDevices = {}
local tableConversions = {}
for _, command in ipairs(tableCmds)
do
altID = command.altid
cmd = command.cmd
if(cmd) then
cmdDeviceType = cmd.deviceType
else
cmdDeviceType = nil
if ((altID and #altID > 0)
and (cmdDeviceType)
and (searchInTable2(tableNewDevices, 3, altID, 4, cmdDeviceType) == 0)
and (searchInTable(tableConversions, 3, altID) == 0))
then
deviceIdNum = deviceIdNumByAltId[altID]
-- Check if child exists but conversion is required
local dev = nil
if (cmd == tableCommandTypes.CMD_OPEN
or cmd == tableCommandTypes.CMD_CLOSE
or cmd == tableCommandTypes.CMD_STOP
or cmd == tableCommandTypes.CMD_ON
or cmd == tableCommandTypes.CMD_OFF
or cmd == tableCommandTypes.CMD_DIM)
then
dev = findChild(THIS_DEVICE, altID, nil)
if (dev)
then
if ((cmd == tableCommandTypes.CMD_OPEN
or cmd == tableCommandTypes.CMD_STOP)
and (luup.devices[dev].device_type == tableDeviceTypes.LIGHT.deviceType
or luup.devices[dev].device_type == tableDeviceTypes.DIMMER.deviceType))
then
table.insert(tableConversions, { luup.devices[dev].description,
luup.devices[dev].room_num, altID, "COVER" })
elseif (cmd == tableCommandTypes.CMD_DIM
and luup.devices[dev].device_type == tableDeviceTypes.LIGHT.deviceType)
then
luup.devices[dev].room_num, altID, "DIMMER" })
if ((dev == nil)
and (autoCreate)
and (findChild(THIS_DEVICE, altID, tableDeviceTypes[cmdDeviceType].deviceType) == nil)
and (isDisabledDevice(tableDeviceTypes[cmdDeviceType].prefix..altID) == false))
then
table.insert(tableNewDevices, { nil, nil, altID, cmdDeviceType })
debug("New device: altID: "..altID.." deviceType: "..cmdDeviceType)
@akbooer - It looks like its trying to search for the altID in existing sensors, do you see any reason for it not finding a previously made sensor?
Suddenly the managed devices list deleted itself, so i started from scratch again, this time with version 1.41. Now Auto Create works, and I can even have responsive motion sensors without using switch device files…
For info, this is the create device in 1.41:
local autoCreate = (getVariable(lul_device, tabVars.VAR_AUTO_CREATE) == "1")
for i, v in ipairs(tableCmds)
do
deviceId = v[1]
cmd = v[2]
cmdType = nil
key = searchCommandsTable(cmd)
if (key ~= nil)
then
cmdType = tableCommands[key][2]
if ((#deviceId > 0) and (deviceId ~= "parent")
and (cmdType ~= nil)
and (searchInTable2(tableNewDevices, 3, deviceId, 4, cmdType) == 0)
and (searchInTable(tableConversions, 3, deviceId) == 0))
then
local dev = nil
if (cmd == tableCommands.CMD_OPEN[1]
or cmd == tableCommands.CMD_CLOSE[1]
or cmd == tableCommands.CMD_STOP[1]
or cmd == tableCommands.CMD_ON[1]
or cmd == tableCommands.CMD_OFF[1]
or cmd == tableCommands.CMD_DIM[1])
then
dev = findChild(THIS_DEVICE, deviceId, nil)
if (dev ~= nil)
then
if ((cmd == tableCommands.CMD_OPEN[1]
or cmd == tableCommands.CMD_STOP[1])
and (luup.devices[dev].device_type == tableDeviceTypes.LIGHT[1]
or luup.devices[dev].device_type == tableDeviceTypes.DIMMER[1]))
then
deviceId,
"COVER" })
elseif (cmd == tableCommands.CMD_DIM[1]
and luup.devices[dev].device_type == tableDeviceTypes.LIGHT[1])
then
deviceId,
"DIMMER" })
if ((dev == nil)
and (autoCreate == true)
and (findChild(THIS_DEVICE, deviceId, tableDeviceTypes[cmdType][1]) == nil)
and (isDisabledDevice(tableDeviceTypes[cmdType][4] .. deviceId) == false))
then
table.insert(tableNewDevices, { nil, nil, deviceId, cmdType })
debug("New device: deviceId: " .. deviceId .. " cmdType: " .. cmdType)
if ((#tableNewDevices > 0) or (#tableConversions > 0))
then
updateManagedDevices(tableNewDevices, tableConversions, nil)
return
temperature sensors, with humidity, couple of motion sensors, and a few nexa switches… all coming in with a new device for each message they send…
Doesnt seem to matter what type it is, same behavior on all of them?
