AutHomationHD 3.1.3.10 Beta
@tedp you can use this https://play.google.com/store/apps/details?id=com.rcreations.WebCamViewerPaid program to zoom and PTZ and even motion detect with any ip-cam
@garrettwp i have this issue when i have my room light dimmer on 1% then it would show as 0% in authomationhd and when i press the toggle switch for it then it would go to 100% instead of to the off status. second press on toggle makes it go off / 0%
A million thanks Da_JoJo for mentioning this app. Thanks to you I could resurrect my old China “noname” IP camera and can use it for something.
Regards
Tomas
I am unable to use voice commands, each time i try… i get a response “I am sorry, i am afraid i do not understand the request”
exorcist when you have a light called : “kitchen light” for example , then you would say to the VR : “turn on kitchen” or “set kitchen to 25 percent” works for me all the time.
you can also change the response in settings > application settings > VR Error Message
I’ve got the two first tabs empty while the third one (showing both devices and scenes) is correctly filled.
I’m n a Nexus 4 with stock ROM.
You need to swipe left to right to access the rooms. To access the menu, you’ll need to swipe right to left.
  • Garrett
A new beta has been posted. See first post for changes.
  • Garrett
Just tried the added “CYCLE” function in the Thermostat. It works great.
Awesome thx for the update!
OrionNE
just got new beta through auto-update from beta play store , seems to work ok :slight_smile: ver 3.1.1.3 after updating
fixed the room toggle and response is faster it seems.
the new font is also better readable
program logic event generator has date and time now
system monitor is really awesome
I love the Tasker plugin integration. This new version is smoother, I like it.
Can I suggest you to add the modification of a variable container into the plugin ?
I did notice that when I am connected (Local) the refresh still showing a “R” in the refresh circle instead of a “L”. Not a big deal but wanted to report it just in case some other logic was being skipped because of this.
OrionNE
same here. but it works ok, so put this low-priority. after mobile networks switch to wifi, shows still “R” after changing wifi 56mbit to wifi 1300mbit it shows “L”
During the first switch it will report the previous connection. After that it should report the correct state. That is because the progress indicator is displayed before the code that checks the connection is run. I have not found an easy way to update it after adjusting the appropriate connection settings. So it’s a low priority cosmetic bug right now.
  • Garrett
I just installed this beta version and I am very happy to see the fibaro3in1 sensor temperature and sonos.
Will there be in the future the option to change (favourite) music on the sonos via authomation?
Many thanks,
Cor
if you make a plugin for vera for playing music, then it could be adopted by authomation. without it is rather out of league for the automation program purpose imho
@ Da-jojo; initially the sonos was not implemented in authomation , now it is. But just play,stop , mute , volume. My question is if it will be possible to change channel/favourites . To do this now , you still have to use a computer or the sonos app. Would be nice if it all can be done with authomation.
Cor
as i do not have a sonos i cannot say it is capable of doing this. it has a interface so theoretical it would be possible . you cannot use Tasker app to control the sonos app ?
@ Da-jojo: no clue what tasker app is , but why would I want that? I have a functioning app (sonos app) works fine, but it would be nice if I don’t have to switch apps and all can be done via authomation.
edit I just read briefly that tasker is something that works together with authomation. But than … I can also make a scene for the different music channels and (un)group the devices. Still it would be nice to have these functions in the tile of the sonos device.
Cor
yes i understand ur point :slight_smile:
would be cool, but it seems not that easy as it looks.
not much to find on sonos steering protocol stuff but i found this [url=http://www.purple.org/sonos/]http://www.purple.org/sonos/[/url] perhaps its usefull and this [url=http://board.homeseer.com/showthread.php?p=700323#post700323]http://board.homeseer.com/showthread.php?p=700323#post700323[/url] this is the most close to vera solution i can find for it. perhaps garrett can tell us if this would be possible to integrate.
