Just reporting my findings. Authomation works on my local network. UI6 uses different relay servers and Authomation has picked up their names correctly but does not connect remotely.
Overall it looks promising, hopefully not too much work to get UI6 supported.
Edit: Authomation throws a 404 error when connecting remotely, the remote URL has probably changed slightly
It was already stated in the UI6 threads. UI6 uses a completely different authentication system which would require all 3rd party app developers to implement. No documentation has been provided yet on this and awaiting for MCV to post it. It will most likely be some time until this is even supported and implemented as it is drastically different from the previous system.
