@rstrouse, I would be happy to test it as well but i am having some stability issues i need to get past before i can install another plug-in (vera3 UI5). In the meantime, in case it is helpful: I have a Jandy iAqualink 2.0 control system for my pool and spa, with one Jandy variable speed pump, one pentair heater, one pentair single speed booster pump for the spa, one air blower for the spa, and one jandy Aquapure salt water chlorine generator (new model). I have a pool light and spa light, both Jandy LEDs (color), and one of my AUX’s controls a “Deck Jets” water feature.
Info on my Jandy controller:
[code]Model B0029221
Type RS-8 Combo
Firmware T.1
Remotes
ePump 02.00 1
iAquaLink WiFi 4
Serial Adaptr 1
AquaPure 1
OneTouch 1
OneTouch 4[/code]
My Autelis info is:
[code]Model: 6520
DIP Switches: 00000000
Software Version: 1.6.8
AUX Labels
AUX1: Booster Pump
AUX2: Spa Light
AUX3: Pool Light
AUX4: Air Blower
AUX5: Deck Jets
(the rest of the AUXes are unused)
[/code]
/names.xml returns a 404
/status.xml returns:
<response>
<system>
<runstate>8</runstate>
<model>6520</model>
<dip>00000000</dip>
<opmode>0</opmode>
<vbat>615</vbat>
<lowbat>0</lowbat>
<version>1.6.8</version>
<time>1470974442</time>
</system>
<equipment>
<pump>0</pump>
<pumplo></pumplo>
<spa>1</spa>
<waterfall></waterfall>
<cleaner></cleaner>
<poolht2></poolht2>
<poolht>1</poolht>
<spaht>1</spaht>
<solarht>0</solarht>
<htpmp></htpmp>
<aux1>0</aux1>
<aux2>0</aux2>
<aux3>0</aux3>
<aux4>0</aux4>
<aux5>0</aux5>
<aux6>0</aux6>
<aux7>0</aux7>
<aux8></aux8>
<aux9></aux9>
<aux10></aux10>
<aux11></aux11>
<aux12></aux12>
<aux13></aux13>
<aux14></aux14>
<aux15></aux15>
<aux16></aux16>
<aux17></aux17>
<aux18></aux18>
<aux19></aux19>
<aux20></aux20>
<aux21></aux21>
<aux22></aux22>
<aux23></aux23>
</equipment>
<temp>
<poolsp>86</poolsp>
<poolsp2>60</poolsp2>
<spasp>102</spasp>
<pooltemp>88</pooltemp>
<spatemp>84</spatemp>
<airtemp>66</airtemp>
<solartemp>0</solartemp>
<tempunits>F</tempunits>
</temp>
</response>[/code]
/pumps.xml returns:
[code]<response>
<pumps>
<vsp1>13</vsp1>
<vsp2></vsp2>
<vsp3></vsp3>
<vsp4></vsp4>
</pumps>
</response>
/chem.xml returns:
>response>
<chem>
<avail>9</avail>
<chlrp>30</chlrp>
<saltp>70</saltp>
<chlrs>5</chlrs>
<salts>70</salts>
<orp1>0</orp1>
<orp2>0</orp2>
<ph1>0</ph1>
<ph2>0</ph2>
<orpfd1>0</orpfd1>
<orpfd2>0</orpfd2>
<phfd1>0</phfd1>
<phfd2>0</phfd2>
</chem>
</response>
Unfortunately pump RPM and watts used only appear in the keypad emulator, Autelis has not been able to get me that info as usable fields (if i could get them i could apply a formula to determine when my filter needs to be cleaned).
Attached are a few screen shots of my Autelis’ UI in case that is useful. Happy to provide any additional info I can.
-mda
