I know app development is dead — but I’m wondering if there is any way to use Authomation and the “Home Modes” in UI7? I just upgraded to UI7 and if possible, would like to set home modes via Authomation.
I still cannot find a better substitute for an Android remote control.
Install the House Modes plugin on your Vera and create scenes to set the modes you need. Then run those from AuthomationHD…
I know the feeling. I finally switched to ImperiHome as I needed the multi Vera support. But I do miss AuthomationHD. If garretwp makes it available on anothert platform that would be a reason for me to consider switching platforms.
I still use it though. I have widget shortcuts on my phone to toggle or set certain states without having to open imperihom or any actual app. It’s sadly all i used Authomation for these days though.
