Hi guys, I’ve seen the VeraAlerts android app but before I buy a Vera I was hoping to find out if it’s possible to send audio alerts to DLNA wifi portable speakers? My plan is to dot a few DLNA wifi speaker boxes around the house and when stuff happens in Vera then audio alerts are sent to specific speakers depending on what the alert/trigger was.
I suppose I could get some cheap second hand android phones instead so will look into that but then would it be possible to send different alerts to different VeraAlerts android phones?
Thanks for any help!
There is no built-in means to accomplish your stated goal. The extensible nature of Vera, using the LUA scripting language makes it possible to write a plugin that could accomplish this, with some external component like a small PC or Android device.
There is a plugin for the Sonos speaker system that does do what you desire.
Your suggested alternative of using Android devices (some people are using Raspberry Pi) would be pretty straight forward.
[I suppose I could get some cheap second hand android phones instead so will look into that but then would it be possible to send different alerts to different VeraAlerts android phones?
The Vera Alerts Plugin is designed to integrate with the Existing Vera Notification mechanisms. You can have Alerts for Different Vera Users go to different profile(s).
Supported Profiles are:
Vera Alerts Mobile (Android for now)
Pushover, Prowl (IOS and others)
SMTP
Vera Alerts LAN (This is just send to Host/Port … others use this for their own notification responder)
Twilio (SMS or Voice to your mobile)
Plugin Forwarding - Can be forwarded to the Say action of the Sonos plugin.
If you have N independently controllable destinations … setup N users for your Vera … When you define a notification in Vera … Mark the appropriate (pseudo) users
You have the DLNA plugin for that. It is a recent plugin I am working on.
You will be able to send audio alerts (TTS) to any DLNA Media Renderer.
http://forum.micasaverde.com/index.php/board,60.0.html
Hey guys thanks for the replies! Ordered my Vera Lite a few days ago so excited to see what I can setup!
