Version: 1.7.730 UI7
Associations are used by ZWave devices to send commands from one device (WT00Z-1) to another (WD500Z-1/PD300Z-2), independent of the controller. Associations can be used to turn on/off a device/light when the WT00Z-1 is triggered on or off.
Associations can also be used to have a movement sensor, when triggered, turn a device/light on or off.
For the normal Association of WT00Z-1:
- Include the devices into your Z-Wave network. Connect to your Vera Device.
- Go to “Devices” and find the WT00Z-1
- Go to “Device Options”
- In the box after “Group ID:” enter a 1 then click “Add group”
- Under the new “Group ID: 1” heading click the “Set to:”
- Find your WD500Z-1/PD300Z-2 on the list and check the box next to it
- Click “Save” at the bottom and wait for it to setup
- Click “Back to ZWave options” button at bottom
- Finally click the “Save Changes” button on the main device page
Now the WT00Z-1 should turn on and off the device/light when used.
