Richard I think I remember something in the past that there was an issue with using the option armed trigger when creating an input that caused it to not work. I would like to use this feature so that I can unarm my motion sensors temporarily so that conditions don’t fire. Had this been resolved?
There is not problem with Motion Sensor triggers … never was … It’s complicated … but if one want to know …
There is a problem with Triggers that have more than one selectable options in the same trigger definition.
Motion sensors have 2 Triggers definitions:
- Armed and (Tripped or Not Tripped)
- (Tripped or Not Tripped)
PLEG is the only device that has created triggers that show the problems … because UI4 and UI5 had bugs I guess others gave up … the API showed it was supported … I provided MCV with patches.
In the UI7 code … I see comments where they at least acknowledge that they need to finish the code to handle multiple options.
In PLEG I have:
- (Armed or Disarmed) and (Condition XXX satisfied)
- (Condition XXX satisfied)
In MCV API each of the parenthesis pairs above is a trigger definition option. PLEG #1 above has the problems.
