Are HomeSeer HS-SP100 WiFi Smart Plugs supported on VeraPlus?
They’re pretty cheap…
If not, recommendations?
Good morning,
You should be able to use that device with us through the Reactor or the Virtual http plugins. Here are some useful links:
https://www.youtube.com/results?search_query=reactor+vera
If you wish, you can also send me a PM and I can try to configure that for you.
Regards,
Vera doesn’t really support WiFi devices.
If the WiFi device can accept a http command to control it, then there are several ways to send those commands out from Vera.
Yup, it all depends on that.
