I have been using AuthomationHD for a while, and I was sure it used to work with my HD camera. But I had problems with the camera so I had changed the stream back to VGA. All working fine in Authomation. Now I have set the HD camera back to HD, and I only have a black picture in Authomation, the SD camera displays ok.
If the stream works in Vera it should work in the app. I am doing nothing special but calling the following url to retrieve the camera stream:
http://<vera_ip>:3480/data_request?id=request_image&lights=1&cam=
- Garrett
