Hello
I?m currently working on an Arduino project that communicates over Ethernet to Vera, I managed to make this work as a client and a webserver at the same time.
The only thing I have problems with are many quick connections to Vera, it seems like the controller becomes slower and slower after some few hours with this load.
Is there any limit to how often and how fast devices can request and update information to Vera? ???
I have a Vera Lite for the moment and my device id is above 100+, could it be my controller that?s too weak? :-[
Currently my Arduino supports:
Register temperature to Vera
Register Light (as %) to Vera
Register Humidity to Vera
Connect to Vera and get current mode form Vera.
Vera can connect to the Arduino with different urls to set Diods on the Arduino
Register motion with a PIR sensor on Arduino and update Mode from Vera.
All code and my configuration will be posted when the beta tests are done. ![]()
I made a YouTube clip to show how it works for the moment
[url=http://www.automatiserar.se/?p=2330]Projekt – Arduino – Hämta Verans Mode (beta) | Tips för ett smartare hem
