I have now posted a beta2 that should be more stable (at least during my tests) and generate less trash-messages.
I also had some serious problems using setPALevel(RF24_PA_MAX) on my gateway that has an amplified antenna version of NRF24L01. So the new SerialGateway (=ArduinoGateway) has a bit lower radio power by default… but you can change it back in sketch if you want.
Need some brave people to test it. The git-repo has been moved to github (Arduino-project) and can now be found here:
Note that this new beta requires you to update both gateway and sensors code due to new ack-mechanism and increased radio-transfer speeds. You can leave the Vera Plugin if you want.
