Does anyone have any suggestion what i could attach to an arduino sensor to detect the angle for a door or gate in degrees? I don’t need a very exact match, 5-10% per step would be enough.
Thank you!
Thank you!
Maybe a gyro would work for you?
I think that would be ok for detecting movement, not the current state based. I’m looking now at bend sensors - https://www.sparkfun.com/products/8606.
This, coupled with a normal open/closed magnetic switch to detect the gate is fully closed will do the job. Ordered the parts and i will keep this thread updated with my findings.
Could you possibly use a distance sensor? ( ultrasonic )
or what about a potentiometer connected to the hinge? or a rotary encoder mounted the same way?
or a series of reed switches?
Rotary encoder looks like a neat solution gregl!
Here are some Arduino examples:
http://playground.arduino.cc/Main/RotaryEncoders
Only problem is how to mount it properly Maybe reed switches are simpler.
