Apps cannot be removed or updated
Hey all,
Some of my apps are not visible in Vera and only partly in ALTUI. They cannot be removed nor updated.
Not sure when this happened, maybe when I updated installed the ALTUI Appstore.
Anyone please help!!
See attached screenshot: Schermafbeelding 2020-05-12 om 01.47.14|690x461
This display is mostly cosmetic, it shouldn’t affect operation.
If you want to delete them, then just directly delete the plugin devices. If you want to update them, do so from AltAppStore.
Well thanks, but it degrades UI7 since they are not visible there. All new plugins get hidden as well and will not get autoupdate so I would prefer it to work as it should. I noticed the 0-x behind the plugin names of the hidden ones where the visible ones have a 0-(sequens number). Is there maybe some table to repair somewhere?
