I noticed that the latest Vera firmware now includes support for the Centralite 3-Series Security Keypad 3400-G
"NEWLY INTEGRATED DEVICES
Garage Door Controller
Digital Home Systems zConnect Garage Door Controller DHS-WIN-GDC-02
Panic Button
Philio Panic Button PSR03-C
Sensors and Multi Sensors
Ei Electronics Z-Wave Smart Carbon Monoxide Alarm EIA207RFZ
Sercomm High Power Micro D/W sensor SZ-DWS08N
Sercomm Water Detector SZ-WTD03N
Zooz 4-in-1 Sensor Ver. 2.0 ZSE40
Switches and Dimmers
It appears that is is Zigbee only so that will limit the compatibility to the Vera Plus users, but if you are looking for a wireless keypad, this may work for you.
Please give us some feedback if anyone is using it.
I added the Centralite keypad to my system and it seems to be working OK so far. My main nitpick is that Vera seems to be treating every code entry as a security alert and sends notification to my mobile phone. I’d like the option to turn those off or limit them to just unsuccessful code attempts. I don’t really need notifications every time the keypad is used. (Just like I wouldn’t need notification of every single time a door/window sensor is triggered in Home mode either.) As a new Vera owner, I’ve been digging through the Dashboard and haven’t found a simple way to customize this. Thoughts from any other Centralite keypad owners? Have I overlooked a setting somewhere?
I have the same issue. Every time the keypad is used i receive alerts. I submitted a support ticket but was told this is normal behavior. It drives me crazy so i just try to make sure i mostly use my phone to arm/disarm.
I have a VeraPlus running 1.7.4125, I also have a Centralite 3400-X 3-Series Security Keypad. Attempting to add this device to my VeraPlus, I don’t see it as a known type of device to add, and it isn’t picked up when I try to add it as a generic Zigbee device (and I’ve reset the keypad by holding down the tamper switch while feeding it a battery, then pressing the tamper switch 5 times).
Is there something I’m missing on setting up this keypad?
