Anyone have ideas for my CCTV analog outdoor cameras
I have 4 outdoor cameras already wired with coax and connected to a DVR. I wanted to integrate it with Vera instead but not sure which way to go. Buying new IP outdoor cameras and wiring them is too expensive and time consuming. I was thinking of an encoder or DVR that could interface with Vera.
Any thoughts.
thanks
Is your dvr capable of being hooked up to the network? If so, you might be able to view each camera stream via a URL.
  • Garrett
My DVR is on the network, has an IP and can also be watched remotely through a DNS
Find out if the dvr has url’s to see each channel. You can than integrate that into vera.
  • Garrett
Apparently from other posts the Defender DVR supports this url thing. Not sure what that feature is actually called to be able to source one that does this.
I am looking for this as well
Start with checking if there is a app available for your DVR.
If you find any then 99% sure you can add the DVR live view to you Vera.
IOS apps that support most DVR /IPcams
[ul][li]Netcamviewer (free version will support 2 cameras)
IP Cam Viewer[/li]
[li][/li][/ul]
Do you have any recommendations? I messed around with Defender for over a 2 weeks and eventually returned it because i could not get it to work.
My iphone did work with it, but i believe it was RTSP stream?
[quote=“TANE, post:7, topic:170154”]Start with checking if there is a app available for your DVR.
IP Cam Viewer[/li]
[li][/li][/ul][/quote]
Has anyone ever tried the app in the store that’s supposed to ease making DVR’s work?
I’m with you. I also have a dvr with 3 cameras connected to it.
I’ve been trying to make it work with my Vera2 but nothing so far… yesterday I’ve found a plugging called DVR - can’t post the link?
I’m now trying to install it but it looks dificult… since I’m not home that might be the problem so I’ll try it latter on.
My 1st post here btw. :slight_smile:
You can not post links as your have a limited number of posts. Once you reach the certain amount of posts, you can post links, receive / send pm’s etc. As for the DVR plugin, it looks pretty generic. You need to make sure you have all of the required information e.g. url, port, ip, etc. Also you need to make sure that your DVR allows of viewing each camera via a jpg link or an mjpeg url.
The reason you are having trouble installing the plugin is that you are doing it remotely. I believe as of right now, you need to be on the same network as the vera unit to install the plugin.
  • Garrett
@Throttleman,
Welcome!
As @garrettwp said, that’s an anti-spam measure. There’s some more; as documented in the FAQ.
Thanks! I thought it was something like that. :wink:
I have part of that information, exception goes to the url for the jpg. My dvr is a Kare (chinise maker). It has been working perfectly with it’s own software for windows and meytech.com for Android. I can view the 3 cameras at once or one by one but I don’t know if it has a url for each camera…
  • Garrett
Yeap, I thought it was that. :slight_smile: Had the same problem with the weather plugin and @ home network it went perfectly. :slight_smile:
[quote=“oTi@, post:12, topic:170154”]@Throttleman,
Welcome!
As @garrettwp said, that’s an anti-spam measure. There’s some more; as documented in the FAQ.[/quote]
Thank you oTi@. :slight_smile:
Well apparently I cannot install this plug-in. From what I’ve read from another topic, it was made for UI5? ???
I’m running a Vera2 with UI4.
