[quote=“mpovolo, post:19, topic:186031”]Got it working. Tech support called me, little did I realize there are two upgrades. There is the SW, then there is also a hardware base firmware that you enter the download link in the second box WRT I think it was called. Now it’s working.
This is the link I used, on UI7 Edge with Latest firmware upgrade. Carefull, you might toast your unit.
[quote=“scyto, post:21, topic:186031”][quote=“mpovolo, post:19, topic:186031”]Got it working. Tech support called me, little did I realize there are two upgrades. There is the SW, then there is also a hardware base firmware that you enter the download link in the second box WRT I think it was called. Now it’s working.
how does one tell a)what versions one edge is and b) what is latest one should install?[/quote]
That was a patch put out shortly after the full upgrade. If you have this problem then install it. If you don’t then wait for the next upgrade. If you try and fix problems you don’t have… You just might end up with a real problem. Don’t do it just because.
